Suzuki dt150/2 stroke,hard start doesn't like to idle???
larryhere
1986 YEAR!!I know its hard to pinpoint like this, but figure i'd give it a shot!!! Takes a lot to start, thought the choke wasn't working, but was! Also when started, doesn't want to idle down very easy, had to turn in the idle screw, and the idle timing increase helps some, but when the idle is right, in a couple seconds, it drops off and stalls! Then to restart you have to choke on and off and throttle up and down to get going! My two ideas are carb cleaning and maybe weak fuel pump or pumps! Any ideas would be great! Thanks larry!
99yam40
Re: Suzuki dt150/2 stroke,hard start doesn't like to idle???
sounds like the right way to go
