Suzuki DT115 No rpm over 3000
olyball
1989 DT115 has 295 hours on it. Have been struggling with several problems over the last few years. Thought I had it all figured out until yesterday. Running great but then at near full throttle, the boat came off plane and the rpms dropped to about 3000. Have had this happen before, but always with an alarm, was low oil. This time, no alarm. Oil is full, water is good.
I am hoping it is not the CDI unit. Is there a list of things to check before spending the $900 for a new CDI?
deejaycee_2000
Re: Suzuki DT115 No rpm over 3000
These CDi's don't ever go bad ..... I would replace the oil flow sensor, water flow sensor, and clean the oil level float sensor ......
James R
You might try disconnecting the throttle position sensor. The motor will run fine without it but if it goes wrong it will mess with the RPM.
