This saga will be long and verbose, but The entire story will let you see what I've done (to no avail).<br /><br />I just bought the boat (20ft Bayliner Trophy '81) with a Suzuki DT115TCLS (9/23/94 mfg, '95 model). The guy I bought it from had been tinkering with it, and couldn't get it started.<br /><br />It had been "running fine", and then got rough, then died. He spent several days trying to get it running and gave up ($6500 as-is).<br /><br />When I started working on it, I checked every coil, every sensor, every connection. Eventually, I found the Flywheel key sheared (about 60 degrees out of time) I replaced the key, and it started right up. It now idles fine, runs smooth, compression is ~115 each cyl., but will only top end (under load) at about 2800-3000 rpm. In neutral, will hit 6K easily. In neutral, it appears to accelerate normally, and at about 2800 rpm, there is a definite change in the sound of the engine (spark advancing?) and it then accelerates rapidly. (None of this happens, when in gear)<br />All sensor readings appear normal, except the throttle position sensor (which was recently replaced). My measurements show only .1 to .25 volts (should be .45 to .55 v at FCT)<br /><br />Even though Suzuki says "CDIs never go bad", I have swapped several "good" CDI units (albeit from older model engines) to see if it was the CDI (No change in performance)<br /><br />My questions are:<br />1. Does this sound like a purely Throttle sensor problem? (any "tweaks" to verify?)<br />2. Since the voltages being supplied are from the CDI (and they are low) does this tend to mark the CDI as bad? ($1000+ to replace new)<br />3. Are there any specific voltage/resistance checks that will positively confirm the CDI is bad?<br />4. Since the engine spins up to 6K with no load, does that rule out gummy carbs?<br />5. Is there any other relatively simple thing that may be causing a loaded top end of only 3K?<br />6. Are there any remote connections that could be shorted/corroded/open that could have this effect?<br /><br />V1700 prop is installed (same one as always) that previously got 5200-5500rpm.<br /><br />Thanks for any help, I'm stumped without more detailed schematics of the "black box".<br /><br />Jim
