Suzuki DT100 -90 Gauge monitor
Jimbob10
Hi, I have bought a Suzuki DT100 -90. Motor has a 6 pin connector for monitoring Oil Level/ Oil flow/ water Temp/ rev Limit Gauge.
Motor came with a GAUGE #part 34700-94631 but this has a missing multiconnector! I have searched how to connect cables to multiconnector to motor. But I can't find anything...
Part book says motor I should use part #34701-92X50 GAUGE (years 89-92). I get confused... Are part #34700-94631 and #34701-92X50 both matching to Suzuki DT100 -90? These Gauges seems to have diffrent cables.
Now to my questions.
1. Can I use GAUGE #part 34700-94631 to Suzuki DT100 -90?
2. How should I connect cables to multiconnector on motor Suzuki DT100 -90 ?
ct1762@gmail.com
Master Chief Petty Officer
you mean the colored leads are missing , or just the connector? if its just the connector why cant you snip off the other ends and bullet-connect everything together? dont the lead colors match up?
Jimbob10
Connector is missing, and the colored leads dont match colored leads on connector motor. I am not sure if monitor #part 34700-94631 is compatible?
Part #34700-94631 supersedes to 34701-92X50 (years 89-92) my motor is -90. My guess is that #part 34700-94631 should work, but colored leads are differently.
