maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 818
I have what I believe a 1988 suzuki 9.9 with oil injection. I am looking for a detailed explanation on how this system works. There is a see through hose at a y junction off of the moto fuel line conncetor. I see a little oil in that tube coming from the oil pump area but I have heard that I have to bleed the system. I had the oil tank out and disconected. How do I bleed the pump? Also the motor doesn't put out a lot of water from the telltale. It puts out some and then stops. I used my air compressor too blow any debris out and it is clear of obstructions. If anyone can help I would appreciate it. Also a tip or two regarding replacing the water pump impeller would be welcome. Where do I disconnect the shift rod on this motor? This is ,y first suzuki thanks
