suzuki dt 85 70 hp
talbee
My friends suzuki dt 85 70 hp keeps running when turned off, with all 3 plug wires pulled, and full line pulled. Ran for about 4 minutes at 5000 rpm
Thoughts?
ondarvr
Sounds like he was revving the motor when out of the water, it can get into a runaway mode and start dieseling, it can be hard to stop, sometimes hitting the choke helps.
talbee
My friend had the muffs on while running the motor, then it started revving by itself. The motor finally shut off, and he's not able to get it started again. We're thinking the gas may be lacquered due to it sitting through the winter.
Any additional thoughts?
ondarvr
Check compression and spark, if you have those then clean the carbs.
talbee
How do we check for spark on this motor?
I'm used to my motor which is a 78-79 Merc.
99yam40
spark tester or timing light will show if there is spark on each plug
it works on all motors
