suzuki dt 25 c wires coil cracked
alson
First of all I congratulate the site because 'it allowed me to make the repairs on my outboard motor
Now I do the following question:
I have a suzuki motor dt 25 c year 1993
I have the wires of the coils cracked and replace broken and I 'can only replace the wires or do I replace the entire coil?
the suzuki manual spare parts for my engine only provides the entire coil.
I expect a response.
thanks
stefano
genova
Italy
99yam40
Re: suzuki dt 25 c wires coil cracked
sound like you will need to replace the coil if you cannot buy separately. A lot of these plug wires are not replaceable
alson
hi, 99yam40
thanks for your answer
I hope you have understood my question. I wanted to know if I can just change the spark plug wire by aftermarket buying them (for example with the kit "SIERRA" I saw on the site).
And if it is possible or not possible to replace only the spark plug wire on my SUZUKI DT25C year 1993?
I looked at the coils and I do not think it is possible because the coil like a single body.
but if you know you can replace let me know.
If it is possible what kind of spark plug wires should I use?
sorry for my bad English if you want I can send photos
single body
thanks
stefano
genova
italy
deejaycee_2000
You can replace the wire only ...... NGK boot and lead ....
alson
Hi deejaycee_2000, thank your answer. I try and I'll know
many thanks and greetings to the entire forum by stefano
genova
italy
