Hello, I'm new to this forum so hopefully I'm posting in the proper section. I have a 2005 Suzuki DF90 that has low hrs. but has been sitting a while. I recently rebuilt the fuel / vapor separator and noticed the trim & tilt wasn't working. I can hear a relay clicking when I press the down switch and sounds like the pump motor running, nothing when I push the up switch. Hyd. reservoir is full. I do have a E-manual but the relay set up they show looks different from mine. Don't know if the procedure and values they give for checking it is the same as for the DF90. Any help would be greatly appreciated.
