bkellyphoto
- Jul 19, 2015
- 2
I have a 2007 Suzuki DF90 with an intermittent stalling issue. At high rpms the motor will stall and slow down then it surges back to speed. It doesn't stall completely, it loses power like its starving for fuel. Never any issues at idle. Some days I can run 10-15 miles before it acts up. Other days I may only go a couple miles before this happens. Once it starts acting up it may run properly for a 1/2 mile to a mile before its happens again. No alarms or codes. I have completely bypassed the fuel tank and water separator, installed brand new fuel line and ball to run off a 5 gallon can and still have the same issue. Have also replaced old thin lines inside the motor. Have taken out VST tank and cleaned and found no sediment or debris in tank or in high pressure fuel pump screen. Has anyone else had this issue? Any suggestions before I start throwing money at fuel pumps hoping that will fix the issue?
