I have a 4 stroke Suzuki DF9.9T/TH kicker motor. I am having trouble where the power tilt will not raise the motor. I can raise it manually. And now I am not able to start the motor. I can start it manually with the key on, and once I turn the key off the motor shuts off. I replaced the ignition switch - figuring that also powers the power tilt - and it worked for a second and quit. So now I am thinking there is something shorting out the ignition switch. Although when I turn the key on the buzzer sounds and once I push the power tilt up or down switch it stops. When I release the power tilt switch it buzzes a
gain, but nothing happens. Cannot start the motor or use power tilt. Do not know if the motor was charging before all this happened. HELP!!
