Good afternoon all. Im working on a 2003 Suzuki DF50, diagnosing no start/run situation. I have the fuel intake off and finding the injectors are not squirting when turning over the motor. I have good spark on all 3 cyls. 12v at the grey wire at the injectors. When I hit the key, fuel pump turns on for 5 seconds, then stops. If I manually ground each injector at this point, they will each squirt fuel.
So I guess Im down to the assumption that the ECU is not firing the injectors. I don't have access to diagnostic software, can anyone help with some tips on where to go from here.
Thank you
Thank you
