Suzuki DF50, how to change oil
peterv6i
Hello,<br />I would like to change the oil in my outboard Suzuki DF50. I have bought an oil filter and oil. The only problem is that I don't know which screw I must unscrue on the block of the suzuki..<br /><br />Here is the image of the block<br />
<br /><br />I have marked 2 points on the block.. Is maybe the screw at number 1 the right one to take out the oil?<br /><br />If is not maybe is the screw No2? <br /><br />Can anybody help me where is the right screw to take out the old machine oil..<br /><br />best regards<br />PEter
bossee
Re: Suzuki DF50, how to change oil
It is the plug You have named 1.<br />You can check at brownspoint.com<br />and Parts Look-Up, DF50 (it is a 9.5 MB PDF File so it will take a while before it appaear on your screen, in Fig. 19 You can see this plug is the oil drain plug).
middleton1
I have a DF70. It's my understanding that you change the oil by taking out a plug on the leg of the motor, just above the water line. Check your owners manual.
