Kiwi Phil
- Jun 23, 2003
- 2,182
I have a 2002 Suzuki DF 50 4 stroke.
We can't get water to come out of the tell-tail....only a dribble.
Can't seem to get anything in the small hole at the tell-tale....wire, whipper-snipper cord, because of the angle.
Mechanic has dropped the lower leg.
Put hose on the copper pipe (think No 6 below) and water does go up and back down, but only dribbles out the tell-tale.
I can blow down the tell-tale, and when I stop, yes water does come out it better....for a second.
Tried gently putting a piece of wire up No6, but it dosn't go as far as the tell-tale, and I can't see an angle sharp enough in the diagram.
Mechanic is checking with Suzuki for opinion.....replacing impellar.
On the diagram, I can't see the tell-tale....can't find any other diagram with it either.
Seems strange
can't get a wire down the tell-tale (angle)
can blow in and suck out ok
Anyone experience this issue before
Cheers
Phillip
1-1 17410-95D11 Water Pump Case 1 $73.78
1-2 17411-94421 Water Pump Case 1 $56.34
S/N 423475 & Later
2 09282-17007 ▪ Oil Seal 1 $6.25
S/N 423474 & Earlier
3 17461-96312 Water Pump Impeller 1 $19.39
4 17471-94401 Water Pump Plate 1 $5.34
5 17472-96302 Water Pump Plate Gasket 1 $1.37
6-1 17560-87J11 Water Tube (S) 1 $23.21
6-2 17560-87J00 Replaced by 17560-87J01 1 $0.00
6-3 17560-87J01 Water Tube (L) 1 $25.23
2003-2008
7 17563-94400 Water Tube Grommet 1 $2.38
8 17565-94400 Water Tube Grommet 1 $2.75
Type:L
9 17566-94400 Water Tube Grommet 1 $2.04
10 17631-96320 Water Filter 2 $4.62
11-1 17635-87E00 Sub Water Filter 1 $3.07
11-2 17635-87E10 Sub Water Filter 1 $3.78
Optional
12 09108-06060 Stud Bolt 2 $1.00
13 09108-06061 Stud Bolt 2 $2.66
14 09125-05046 Screw 5x12 2 $1.03
15 29141-93J00 Nut 4 $1.06
16 29162-93J00 Washer 4 $0.82
17 09420-04006 Key 1 $2.38
18 03142-04303 Screw 2 $1.27
19 09116-06094 Bolt 6x15 1 $1.34
20-1 56130-94413-0EP Drive Shaft Housing 1 $115.61
1999-2004
20-2 56130-87J00-0EP Drive Shaft Housing 1 $111.87
S/N 510001 to 510465
20-3 56130-94413-0EP Drive Shaft Housing 1 $115.61
S/N 510466 & Later
21 09263-25025 ▪ RN 25x33x15 Bearing 1 $14.87
1999-2004
22 09282-17005 ▪ Oil Seal 2 $3.84
23 17400-96352 Water Pump Kit 1 $24.38
Optional
Seems strange
Cheers
Phillip
S/N 423475 & Later
2003-2008
Type:L
Optional
1999-2004
S/N 510466 & Later
1999-2004
Optional
