Mike Ansell
- Jul 20, 2003
- 1
I have stripped a 3.5hp 2stroke, for one of the<br />handicapped youngsters in our yacht club, as they thought it had seized,<br />however the fault is that the drive shaft had corroded into the lower<br />extention from the engine..(this is the alloy casting that carries the small seal, just below the lower main bearing seal).this appears just to have been because the<br />engine had not been fresh water flushed after normal sea use...this has been<br />easily cleaned up, but does not appear to have any normal means of<br />lubrication,,,,any advice on this point or past experience of the same would be appreciated...<br /><br />Regards<br /><br />Mike
