Suzuki AGING
SPOONS
I've got an older model Suzuki in pieces. I believe it is a DT40 I need to figure out what year the motor is. Any clues as to where to find the year? Does the serial number give that info in some cryptic way? How? In anybody's opinion would a late eighties early nineties be worth putting money into? :confused:
Kiwi
Re: Suzuki AGING
Whats the serial number Spoons ? <br /><br />Mike
CAPTBLACKSMARINE
Re: Suzuki AGING
LOOK AT THE SERIAL # IT SHOULD LOOK SOMETHING LIKE THIS 456815-986321 THE FIRST #IN THE LAST SET OF DIGITS IS THE YEAR MODEL THE SERIAL # I TYPED WOULD BE EITHER A 1989 OR A 1999 YOU SHOULD BE ABLE TO LOOK AT THE MOTOR AND TELL THE DIFFERENCE A MOTOR THAT IS A FEW YEARS OLD OR ONE THAT IS TEN PLUS YEARS OLD
Bear
Re: Suzuki AGING
Blue engine 1980-1982<br />Light gray engine 1983-1988<br />Gray engine 1989-1996<br /><br />DT40 Model/Kode <br />'80 G, '81 J, '82 VZ, '83 QD, '84 VE, <br />'85 VF, '86 VG, '87 VH, '88 VJ, '89 VK, <br />'90 VL, '91 VM, '92 VN, '93 VP, '94 VR,<br />'95 VS, '96 VT <br />
<br /><br />First digit is the last digit in mfg year, the rest is engine number. <br /><br />Does this make sense Spoons?<br /><br />/Bear
