Suzuki 9.9 TH electric won't start
sturgeonx
I have a suzuki 9,9 TH (2008) with remote control and electric start that won't start. it won't even turn over. It does start manually when I turn the key and crank it with rope.Here is what I noticed and any help would be appreciated.
1.I have power to the unit, the power trim works on both the motor and with the remote control.
2. I checked the fuse in the motor housing and its ok.
3. I checked to see if it's neutral, the shifter moves into forward and reverse and I can see it moving in the housing. when I try to start it with the key it seems like if it was not in neutral but this seems to be ok.
not sure what else to check
thanks for your help
Sturgeonx
