Re: suzuki 88 dt55
At least you know what the problem is, its not getting fuel on the startup. You stated when you had the heads off you cleaned the carburetors, by that do you mean you disassembled them and cleaned each jet with solvent and compressed air and put in new float seats and gaskets or you just washed them off. It is possible that if they weren't properly cleaned and disassembled, by removing them and shaking them up some crud has found its way into the idle jets or somewhere. But back to basics,<br /><br />1. Was the fuel bulb pumped up tight?<br />2. Is your choke working and were you using it?<br />3. Did you readjust the idle mixture screws to the proper setting?<br />4. Are all the fuel hoses that you took off in the disassembly back on tight with no splits or holes?
