suzuki 65 remove foot / lower unit
riverrunner22
trying to change the impeller. dont have a manual. any tips on disconnectiong the linkage or anything else? I've worked on 25's but not a 65.
BTW, its a 95' DT65.
Thanks!
deejaycee_2000
Re: suzuki 65 remove foot / lower unit
It is the same procedure as with the 25 ..... loosen the bolts slowely (spray with WD40 before hand) loosen the linkage at the back, drop the lower unit ....
riverrunner22
i figured it out. 1st off there was a bolt near the anode i had to take out. also, the linkage disconnects under the bottom carb. thanks for the help though!
