suzuki 30hp
rkoenigsma
i have a 1990 30 hp oil injected suzuki just rebuilt couple weeks ago. new pistons everything for $1200. it overheated due to not pumping water so we got a new impeller installed. it was pumping real good when we got it. when i ran it w/the ear muffs it would pump real good like in the lake. i ran it today to run the gas out of the motor and it wasn't pumping water good but a stream of water was comming out. will it overheat if not enough water is pumping out? i don't want to spend 1200 again to rebuild it.
Case
Re: suzuki 30hp
A stream of water was coming out where exactly? Are you sure you installed the earmuffs correctly? Was the water turned on all the way?
