Ok found the barrel nut and jam nut. Loosened jam nut up, then assumed the barrel nut goes up as well, to unthread from lower shift rod. It only goes up so far and then stops though tight. Not enough to unthread from lower shift rod. Am I doing this correctly? Do these just get corroded?
