I took out my boat (2001 Campion explorer 19 FT) this saturday and it it was leaning to the port side under full acceleration. I did not do this when I test drove the boat 3 times and when survayed. It has two batteries and I put in a different battery that is a bit heaver on the port side, but I do not think it would make that much difference.<br /><br />I am thinking that the trip tab on the bottom of the outdrive must have got bumped out of wack a bit. It is a 150 suzuki.<br /><br />My questions: 1. Does weight distribution effect the lean of the boat that much????<br /><br />2. When I adjust the trim tab on the outdrive, is it real sensitive, or should I move it a good inch or 2 ??????<br /><br />PS pulled a real dumb move when hooking up the battery.... hooked the cables up backwards and ended up spending a good part of the day tracking fuses down. I was a mechanic for several years and have never done that.... I was so excited to get the boat out I was not paying attention. Felt like a real dumbass as my friends were as excited as I to get the boat out......<br /><br />thanks <br /><br />Doug Lear
