Suzuki 115 pee hole ?
sports24-7
I just purchased a 2003 Suzuki 115. I took the boat out 2 times for a few hours each time. I cannot find the pee hole where the water comes out,
I'm not sure if I'm looking in the right place. PLEASE HELP.
Thnaks
D
DJ
Guest
Re: Suzuki 115 pee hole ?
It is usually on the Starboard (right) side coming out of the lower engine pan. Look for a small fitting in that area, usually plastic.
sports24-7
I can't seem to find it. I guess I'll try and look again tommorow. Should it be pissing whenever motor is running ?
James R
The answer to your last question is Yes. Suzuki's have a strong tell tale when everything is in order. It is not uncommon for the jet to block up. Try a plastic tube from a spray lube can or similar and clear the jet. As told it is under the starboard side of the lower engine pan.
triumphrick
Once you locate it, you can use some 80# - 100# mono to chase up in there and help to unblock it...it will flex along the rubber line leading to the outlet.
sports24-7
I must be blind, stupid or just can't see , I can't seem to locate it ! !
The only hole I can find is behind motor . Could that be it ?
James R
The engine cover is in two parts. The upper, which you remove to expose the engine and the lower which the upper attaches to. The lower cover has the telltale jet fitted in it. Look toward the rear on the starboard side just underneath and you will find the plastic jet.
sports24-7
Would anyone have a picture, so I could see exactly where it is ?
Thanks for all the help.
sports24-7
WOuld it be in back like this one ?
James R
You did not say that it is a 4 stroke. The drawings for the four stroke show that there is no tell tale as we were describing. The only indication of water flow is as in your photo.
