andrew j cox
- Feb 11, 2015
- 149
Got a Suzi with some problems, no thermostat in it, with the muffs and thermostat housing off getting no water out the top but bit of smoke coming out.
i have to dump the gearbox to have a crack repaired, he had the pump done but wasn’t tested, if the vanes were reversed this would occur? No water out front of the leg through the little exhaust outlet below the bottom cowl, I can put hose down the tstat hole and it comes out the prop n a bit from the fore mentioned outlet, stick hose in this outlet get water out exhaust but not out the top, so my idea of likely causes, blockage inbehind exhaust plate, blockage in head, she’s been in the salt all it’s life, water tube to pump seal up the **** or pipe dislodged, impeller back to front, what way should the vanes rotate? Left or right looking at from top of box with prop pointing north. could the head gasket be suspect? Plugs are clean compression is dead even at 140 from 1 to 3.
