Survey company in Wisconsin
gm280
A "redirect" means the mods moved this to the appropriate forum.
As for a moisture test, you have to remember this boat is 30 years old. If it was stored outside for any length of time, I can tell you there is moisture in the boat for sure. How much and where is also easy to know, any place where they used wood like the transom, stringers, bulkhead and of course the flooring. So it you want to save the money, you can drill some ~1/4" or so inspection holes in those places and see if you get dry light colored shavings out. If so, fill in the holes with some epoxy, polyester resins or 3M 5200 sealant and happy boating. If you get dark wet shavings, you have rot and water issues that certainly needs to be repaired before boating anymore. Drill as close to the bottom of the transom and stringers for those test holes. And of course from the inside of the boat and not all the way through...just enough to see the shavings. JMHO
cloud_master
I already know I have some water logged structure in the back. I wanted the survey to see if it could help me identify where the water may be wicking in from. Bildge is dry as a bone, but my inner stringers are wet.....
gm280
When you rip out the known rotted structure, you will see where the water in coming in. With that much rot, it will be obvious. Of course if you just want to spend money, go for it. But since you, or someone you may hire, will be replacing the rotted structures, you will see the problems too... JMHO
