I put a 83' Suzuki EL50 in the water for the first time today after getting the carbs rebuilt for me (it sat up for around 3 years). It seemed to run semi-normal except at part thottle it bog slightly then surge ahead. At full thottle it would run well but bog down on occasion. I was worried about the impeller, but it seemed to have a good spray out back. However, the pisser only seem to be running half strenth except in reverse then the stream would get stronger. My question is if a weak impeller could cause an intermittent problem such as this or should talk with the would rebuilt the carbs?<br />I will appreciate any help.
