Supersport Windshield
justmissed
I have a 1971 16' Supersport. My windshields are in terrible condition. The frames cracked and i screwed them back together, but I need to replace them. Where can I find them? I have searched with no success. Any help wold be appreciated.
John
STARCRAFT16SS
Re: Supersport Windshield
Where are you located...anywhere around ST Paul MN..????
I posted that I have a 1971 16ft Starcraft Supersport windshield to be given away for free...
the pexiglass is shot and needs to be replaced...this windshield does not have
the center swing door/window..
Also giving away the consoles that came from a 1977 or 1978 16ft Starcraft Supersport
The consoles are missing the dash...
I replace the windshield on my 1971 Starcraft with one from a newer Starcraft Supersport
that has the center door/window....don't need the old one anymore...:D
VanderLaan
I have a set from my 78 Holiday that I do not intend to use. They even have wipers! I am in central Illinois.
VanderLaan
I just read your post again and noted that your boat is a 16'. Mine is a 22'. I assume that the beam on the 22' is wider than the 16'. It would still work, if you do not mind the edges hanging over the side. :eek:
GA_Boater
If the guys up there don't have one that fits your SS search CL. Do you have the center window? I found a five piece with the center window, all glass, on CL for $40 a month or so ago. Came off an old Ebbtide. W/S's are W/S's. Starcraft used a lot of Taylor Made and so did a lot of boat makers, even today. All you need are the measurements of your current W/S. Good luck.
GA_Boater
You can check the taylor made website but I think today all they make are swoopy, curved W/Ss. Best bet is still CL or eBay. Good luck.
