Super Quiet Johnson 40
Swampfox
Hey there from the north. I have a 40 horse Johnson that jerks coughs and then stalls at idle also there seems to be alot of gas oil mix in the lake when I shut it off. Could you help me? Thank you very much anyway I realy like this forum. Swampfox.
JB
Re: Super Quiet Johnson 40
Hey, Swampfox, you need to attach your second message to this one, not on a separate topic. What have you done about setting the idle and synch?? It sounds like your idle is too slow and that the carbs aren't working together.<br /><br />Do you have your manual yet?<br /><br />Standing by.<br />JB
Swampfox
P.S. Thanks for letting me know about making an attachment Mark
kev_79
Checks carb bowl, sounds like float might be stuck. Rebuild carb wouldn't be a bad idea, shouldn't cost more than 10 bucks.
Swampfox
OK sounds good I have the kit on hand. What would make the motor jerk like it does then stall? Thanks, Mark
