super loud buzzing noise as i turn the key
mikelu5
i have a 17 ft sea nymph with a 70 horse johnson and when i turned the key i got a super loud buzzing noise. 2 hrs later the noise was gone. anyone have a clue?
suzuki40
Re: super loud buzzing noise as i turn the key
My suzuki 40 hp 4 stroke makes that load buzzing noise when I turn the key. but stops after it starts. It is the low oil pressure warning on my motor.<br /><br />Suzuki40
suzukidave
what kind of buzz? (many jokes come to mind)but do you have oil injection and could it be your oil mix low alarm?
mikelu5
it's just loud, no other way to say it. it's an OMC. it came on as i was running. then after i shut it off i turned the key and there it was again, 2 hrs later it was gone?
KennyKenCan
It sounds like you were OVERHEATING!!<br /><br />You should go to the outboard forum to get your questions answered.<br /><br />Kenny
Bco128
as a first guess to this i would say your impeller is shot.common problem if you dont replace them regularly.usually inexpensive a.d not too difficult to replace.Buzzer defenantly sounds like an overheating alarm.
joe curalli
I have this same problem on my 75hp evinrude... very loud buzzing.. what can cause overheating? what does the impeller do?? i am a amateur to boating? please help
joe curalli
can over heating be cause from little oil??? I have a loud buzzing thing happening as well.. I do not know oil ratio exactly... would this cause to run very rough as well??
bassboy1
Yes, that buzzer is the overheat alarm. Yes joe, overheating can be caused by lack of oil. Also, it can be caused by lack of cooling water. Unlike a water cooled car engine, that has a radiator to keep cooling the same water, an outboard uses water from the lake to cool the powerhead. It then spits it out, and picks up new water. Very practical, seeing as outboards are only gonna get used in water.
With yalls motors buzzing, it means either; there isn't enough oil, or there isn't enough water cooling it. Those are the main two reasons. As for not enough oil, joe, what year is your motor? After 1964, they were 50:1 ratio. You better be measuring it, and not just pouring some in after filling the gas. Or, if it is from lack of cooling water, it means that the water pump is not pumping correctly. If that is the case, it is usually a bad impeller that won't get a good suction of water to the engine. The impeller is a rubber piece that makes a seal, and that pushes the water. They desinigrate over time, and once it stops making a good seal, it stops giving the outboard enough water. These need to be replaced every year or 2.
Or, your whole water pump could be dead. Joe, how long have you been running with the buzzer on? You may have greatly shortened the life of your good outboard. Mike, did the buzzer start when turning the key with the engine cold (been sitting for a day or so) or with it warm (ran within the last hour or so) If cold, it could mean your buzzer is goofy, but if hot, it may mean that the engine was overheating. The reason I ask is, it shouldn't be instantanious, as the cold outboard is gonna need to run for at least half a minute for the lack of water allow it to heat up. And, if lack of oil, it will take a few revolutions for it to have enough friction to heat it.
joe curalli
thank you bass boy. I have not ran it since the buzzing started... been to worried. I should try it now that the engine is cool., I have had the water pump replaced already and water seems to be pumping out just fine, would the impeller still be bad you think?? I have an air leak by gas tank fitting and i think this causes hard starts when i have been sitting for a while, is this safe to asume?maybe gas line had air and or not enough oil? i ran out of gas and refilled this is when i had the buzzing noise after running for only a couple minutes roughly, while starting and stopping to figure out problem. never ran it after buzzing started, I rowed in( how humiliating) 1984 75 hp evinrude 50/1 oil ratio???? thank you so much for the reply
