i drained the oil tanks, (remote and engine mounted)
blew the water out of the cylinders, (starter still worked)
blew the water out of the oil lines from the oil tank (crank pressure and feed line)
I'm trying to get a hold o a DDT to prime the oil pump with fresh oil
I drained the VST tank
I just took the oil lines off the compressor and spun it over
do I have to do anything with the compressor?
Should I take the fuel rails off and clean them out?
Does anyone know if I should do anything else before I try and crank it up?
Thanks in advance
Thanks in advance
