Sun Tracker Party Barge 22 - Mercruiser 3.0L won't fire
Simmons647
We are at our wits end. I need helping figuring out why Powerwire for coil is grounded. Where does that purple wire go?
Here is everyhting else i tried:
1. Replaced - Rotator cap, button, sparkplug wires and coil
2. Jumpered out engagement switch and cutout switch
3. Checked safety switch and line
4. Isolated tack ometer
5. Put a fire light on it - it fired a couple of times when i isolated the tack
Ayuh,......... Welcome Aboard,...... The purple wire, is the ignition circuit,... power from the key switch,....
Simmons647
Thank you! We tracked that down, still no luck. Every once in a while it will start and run for a few but not consistent. Any ideas would be greatly appreciated!!!
