Suggestions- hooking up accessory power
crimsonlord
I run a 3 battery system... two deep cells for my 24 volt trolling motor and my main starting battery for a 112 Johnson.
I have standard components lights, horn, depth finder, radio, bilge, aerator and bait pump.
Currently all accesories are hooked to my 12 volt starting battery, I guess since it recharges when the motor is running. I only have the option to run all accessories to one battery. I have 10 gauge factory wires (red&black) coming under the deck from the center consoles and it's about impossible to fish new wires.
Should the accessories be hooked into one of the 24 volt deep cells or should I just leave it as is? Never had any problems but since I am checking all the wires. I'd like suggestions for what is correct.
Thanx in advance,
-=Fred=-
Silvertip
Re: Suggestions- hooking up accessory power
That's the general set-up for most fishing boats including mine. No need to change anything.
