Suddenly no oil pressure
NHGuy
I have run the boat all of 30 minutes this season. 25 minutes from the launch ramp to my slip at around 2500 rpm.
And today it was beautiful out so my daughter and I thought we would go for a ride.
Normal start, ran it up to 2500 or 2800. The water was so smooth, so I gave her some gas. Everything looked and sounded great. I ran it up to the speed limit which is 45 mph, the motor was only spinning around 3500 or somewhere around there. When I looked down, oh no, oil gauge is zeroed. I grabbed the stick and shut it down. Checked the oil, perfect level. Wiggled the connections to the gauge, nothing. So I got a tow in and brought it home.
I tried a mechanical oil gauge, it stayed down there. I also tried a few shots of air down the oil sender hole but nothing. I tried leaving the mechanical gauge plastic tube hooked up and ran the motor and got a tiny little bit of oil. Maybe a pound or 3 of pressure. Normally I get 40 psi cold at 800 or 1000 rpm with fresh 40 weight Pennzoil. The idle pressure drops off to 15 or 25 after the motor gets warm.
I put an ohmmeter on the sender, it was a perfect 259 at zero pressure.
Here is some background, I pulled the motor last fall and changed the oil pan gasket and a lot of the other gaskets too.
I fear that I botched the reinstall of the oil pump cover somehow. I will confess that I put vaseline in the pump gears as a priming assistant.
I don't recall touching the pickup screen & tube because the Merc manual says stay away. But I also don't recall even touching the oil pump cover at all. I must have had it off though, how else could I have vaselined the pump gears. That was last fall. So it's fuzzy in my memory.
I'm about ready to pull the motor, but I though I'd put it out there for discussion. I guess I will change the oil filter first just to eliminate it as a concern, but that would surprise me.
Man, I was so ready to do some boating!
Don S
Re: Suddenly no oil pressure
It's not the oil or the filter. The oil pressure sender passages are before the filter. You have pump, or pickup problems, or the drive shaft from the distributor is no longer turning the pump.
While it has nothing to do with your problem, why wouldn't you use oil instead of Vaseline in the oil pump????
NHGuy
The most trusted mechanic I know uses that method. But Mercruiser, and apparently you, do not. So I think I am done with vaseline.
I'm planning to pull the motor this weekend...
Thanks for confirming, I hope it's the pickup, they are cheap and readily available. The pump is a little farther away.
What a dopey design, press fit.
Don S
Once the pickup is set to the desired position and tight just tack weld the tube so it doesn't come out.
NHGuy
Guys I have to confess. The moron (me) who had the oil pan off for reseal primed the oil pump, but didn't torque it. Once the motor had a little run time the pump bolt started backing out and the oil bypassed the sender.
Result, a whole 90 degree summer Sunday wasted removing & reinstalling the motor to get to the pump.
At least I got to clean up the mess my power steering leak made.
Hope you all had a good day boating! Wish I was with you.
Instead I paid the idiot penalty. Well, that's a tank of gas saved.
NHGuy
Yup Don, I had a pump and a Chevy truck pickup in my hand to put in and decided against it when I discovered the pickup is for a shallower pan than mine. If I had set it at the correct depth the pickup would have been at an angle. So I tested the original pump and it was working fine and smooth.
It's back in the motor now but I didn't finish the install tonight.
I was too involved in cleaning my bilge and getting my motor clean too.
When I run the motor I will have fingers crossed that all is well. If I have a pressure problem I am gonna cry. I suppose I can run the oil pump through the distributor hole, but I really don't want to mess with the timing. It's running so well.
gowapiti
Interested in how this turns out. I have experienced a similar problem only when my oil pressure dropped to zero, I felt a surge and then no pressure. Checked everything out and had good oil level, not milky. Restarted the engine and ran it up in neutral and about 1000 rpm the pressure dropped to zero again. Shut down and pulled the motor, pickup was still attached, not plugged up and air flow through pickup screen was great.
can't wait to hear how your project comes along. I picked up a a couple of ideas from your thread. Thanks!
ricohman
I think you saved the motor by playing it safe and getting a tow:)
I know a lot of guys who would chance it being an electrical problem and run it back to the dock.
