I'm pretty sure I sucked up some sand on my last outing. No problems getting back(no overheating). I'm in fresh water so I figure it's flushed itself. 2 weeks later(now), I put the muffs on and fire it up. Reaches operating temp. and then some. I see steam so I shut it down. Pull impeller, cooked. With impeller removed I turned on the muffs but no water was reaching that area. My questions are; Does the impeller "suck" the water up to it? If muffs are pressurized should the water flow freely through the ports with impeller removed or maybe it's clogged somewhere and how could I flush out the clog? It's a 4.3 OMC Cobra 1988. Sorry this is so windy & convoluted. Thanks for any tips.
