Sea Rider
- Sep 20, 2008
- 12,345
A friend of mine flipped his rib with a 2 stroke 18 HP attched on transom while towing it behind a sailboat, This happened off coast on clear sea water, don't know for how long the engine was submerged. When the engine was taken back to terra firme hours latter had both plugs removed and flushed with fuel/oil mixture.
Don't know if carb was taken apart and disassembled, friend tells me that managed to start back engine, Question ; Asume electric components under flywheel were not rinsed with fresh water at all. Was wondering if will be ok to flush them with a hose watering them through upper side of timing plate and then drying with compressed air ? Or better is removing flywheeel and rinse/clean manually all electric components.
Squirting mixture through carb while engine is off is not same as removing carb and fuel manifold to have better access to interior components to provide a proper interior flush.. Was wondering if engine is already back to life to squirt an overdose of power tuner as to clean whatever sea water was left inside crank case, will this procedure work ?
Dislike removing manifold as there are gaskets involved that might break into pieces if removed and don't have those gaskets at hand to seal back manifold.
In the short time period, would you say that already all interior bearings are compromised due to salt water intrussion and consequent latter oxidation and rust and that engine could be jammed any time soon while in use ? Tomarrow will have a look...
Happy Boating
Happy Boating
