SpinnerBait_Nut
Thread starter- Joined
- Aug 25, 2002
- 17,651
Here is the scenario.<br />1995 Outback, 2.2L engine and automatic.<br />176K on the clock.<br />No problem out of this car at all until yesterday.<br /><br />Use this car ever day on a 80 mile stop and go route.<br />Wife pulled up to a box and it died. Tried to start and just crank.<br /><br />Turned key off and back to start and it started up, idled rough and then<br />died again.<br /><br />Did this 3 times and the last time it started up, idled right and ran good<br />the rest of the day.<br /><br />Throttle up with no problem, 5 to 6 K and even smooth shifting. Running A/C<br />all day also.<br /><br />Now this AM, she is out on the route and about an hour into it, same thing.<br />Just little hiccups.<br /><br />She could gas on it and it would take gas and go on, but come back to idle and<br />it would like surge from idle to 3K and back to idle and then die.<br /><br />Brought her one of the vans to finish her route in.<br /><br />Let the car set for a few minutes and it started up and ran for about 10 minutes<br />fine and then same thing.<br /><br />Well, thought maybe it might not be venting right so I took the gas cap<br />loose and it had pressure on it as you could hear it coming out, don't know<br />if it is suppose to do that, but it did so I left it loose and ran the car<br />that way also to no avail, same problem.<br /><br />Let the car sit for about 30 minutes and started it up and drove it the 8 miles back home without a problem till about 1/2 mile from the house and then a small hiccup, but didn't die.<br /><br />Also I noticed under hard romping that at around 3K, you can hear a high pitch noise alomost like it's sucking air around a hose somewhere.<br />Could this be what I am hearing and if so, could this cause the above problem?<br /><br />Now it sits here waiting on me to fix it.<br />Please, anyone got any ideas that I could check/try?<br />I hate these come and go problems.<br />Need help/advice ASAP. Don't want her using the new CG on the route.
<br />Thanks
