Stupid TRUCK trick
lark2004
Re: Stupid TRUCK trick
that happened to my ford econovan, only it was the timing belt tensioner.....
jtexas
Originally posted by rayjay:<br />
Ignoring it doesn't fix it.
You just need show more perseverence when ignoring a problem. <br /><br />Then you will discover that ignoring a problem long enough does indeed cause the problem to be fixed.
Hard to argue with logic like that! <br /> :D :D :D :D :D
Reel Poor
Rodbolt----many engines with serpintine belts dont use bolt on drive pullys. The groves for the belt are cut right into the outer ring on the balancer/damper.
Reel Poor
Like lark2004 said timing belt drive assemblies also use these type bearings in tensioners and idler pullys. So dont opt for the CHEAP repair. Change "ALL" timing belt drive componants. Waterpump also if driven by timing belt.
