ajgraz
- Mar 1, 2010
- 1,858
1978 Mercury 70hp 3 cyl.
I am awaiting a new set of ignition coils, everything else is in place and wired up on the powerhead (trigger, stator, switchbox, rectifier, internal harness; starter and battery power and ground, though ground currently disconnected at battery).
I'd like to get started on the initial (crank speed) timing settings (i.e., begin the link & sync process) while awaiting my coils. Already got my timing pointer aligned.
Stupid questions:
Will it damage the stator, trigger, or switchbox to crank the motor without the coils installed?
If so, will it damage the trigger to crank the motor with it disconnected from the switchbox? How about the stator if disconnected from the switchbox and the rectifier?
Stupid questions:
