I hooked up my battery opposite polarity Negative on Positive and vice versa. When I turned the ignition, the fuse blew. I changed the fuse and it worked fine. However, after running it for a while, it didn't turn over. Also after two hours of running, when I tried to crank it to flush, it didn't turn. I waited a few minutes and it worked fine again. Did I fry something? Help. 1999 Honda 50 hp can no longer be trusted.
