akriverrat
Thread starter- Joined
- Oct 31, 2002
- 588
had 35 hp tiller steer johnson off boat to do some maintanence. put it back on for test run. just a few minutes. will install hold down bolts later if every thing ok. test run fine. coming back to dock full throttle. throw it into hard left turn to slide boat sideways up to dock. hot dogging,but private dock and no one else around to be bothered by it.i am twisting throttle to idle but engine speed is increasing.i look back, handle pulls out of my hand,and watch engine make 2 360s on its way to the bottom in 10 feet of water.amazingly,after waiting for tide to go out, flushing motor with fresh water and running it with rich oil mix to dry it out it was undamaged and went on to give me several more years of good service. the bolts they supply with the motor are there to be used evidently.
