Re: stumped!
Ok. The coil when ohmed across the two post ohms open. Where as all five other coils ohm across the two post 246 ohms. I checked for spark on the subject coil and did have spark, however it appeared less then one of the other coils that I checked. The main issue is when I first start out in the water the motor runs very rough and sometimes after 5-10 minutes the problems goes away and will not return until I let the motor sit for at least 12 hours. Lately, the problem has bacame worse. What is the small device with two wires that has a fuel line connected to it? Thanks for any help.
