rustyscrew
- Mar 29, 2006
- 141
Still wrestling with a problem that has me stumped
Engine: 1994 120hp Evinrude OB
Problem: Starts up fine, sounds like all cylinders. Runs for a 30 seconds or so then starts to cough. Loses cylinders and can run for awhile but pretty sure its running on only 2.
History: Was having hard starts but ran OK. Figured it was time for carb cleaning. Usually I would clean and not replace any parts and it would always run better. This time ordered the kits and replaced all parts. That is when the problem started. Since then I have tried everything I can think of and stuff that this forum has suggested.
I am pretty sure I lose the both left-side (port) cylinders because the new plugs were quickly fouled and wet after one 2 minute running. WHAT might cause both of those cylinders to be bad?
What I have done:
1) Rebuilt all 4 carbs twice.
2) Checked for spark (with proper tool)
3) Checked compression
4) Replaced plugs
5) Replaced inline and spin on fuel filters
6) Tried alternative gas tank directly to fuel pump
7) Tested fuel pump pressure (5 psi and holds indefinitely)
8) Spray fuel into carbs while running. I can keep all cylinders running this way. Hard to tell exactly which cylinders it responds to. Definitely top-port.
9) fixed a busted wire in the computer on top (didn't change performance)
I was about to redo the carbs....then felt like that may not be the problem.
Any thoughts?!?
thanks
What I have done:
4) Replaced plugs
Any thoughts?!?
thanks
