Stuff coming out of breather
Slessard
Started the day with this
https://youtu.be/VWCoV83Xviw
Creamy brown water coming out of breather. Actually this has been happening for a while now as I ended up with that stuff at the bottom of the boat. Seriously clogging my bilge pump and I didn't know where it was coming from. Brought it to the mechanic and kept telling he couldn't figure out where it was coming from. Now I know.
Doesn't seem to affect power
Cracked blocked?
Change oil. If it comes black, could be cracked block or leaking manifolds
You can also remove the elvows and manifolds and inspect them
You can drain the jacket water and pressure test
Faztbullet
If that water coming out breather tube there is no way oil is immaculate...water out breather means water in valve cover which means water where oil supposed to be...
unless you have drained the oil to look at it, the milk-shake oil will not be in the dipstick tube until the internal pressure of the milkshake oil has pushed all the oil up the dipstick tube, which normally requires the dipstick to not be in the tube with the motor running.
Slessard
My mistake pan is a big messy milkshake ... will be dismantling the engine to see what is going on.
