Stuck Throttle of 2.5 Johnson
DaveWave365
I have a Johnson 2.5 J3RCUA with a throttle that only moves about 1" . The throttle cable is connected to what looks like spark advance. I have not traced how the carb is operated. I have not started the engine yet. Is this normal for this type of engine, or is there something sticking? Any likely problem spots?
Thanks,
-Dave
Vic.S
As you increase the throttle setting it advances the ignition timing, as you observe.
The magneto base plate has cam attached to it which bears on a roller on the carb linkage to open the carb throttle plate at the same time..
Check that at minimum throttle setting the roller is not quite touching the cam and that the throttle plate is almost completely closed, and that as you operate the throttle control the two just come into contact where the cam is (hopefully) marked.
As you continue to operate the throttle control the throttle plate should progressively open so that at throttle maximum setting it is fully open
BTW the correct fuel mix for this engine is 50:1 regardless of what any surviving decals may say,
The latest recommended plugs are QL86C gapped at 0.030"
DaveWave365
Thanks...I gave a bit of lube and got it to work. There is a lot of mass moving, and it felt like it was binding. I had no idea the whole plate would move. It drives the throttle with a cam. Monkey motion for sure,,
