stuck powerhead please help
longboard85
I hava a 1996 evinrude 70hp that i am pulling apart to rebuild. My problem is that the powerhead is stuck i broke 2 of the 6 main bolts that bolt up from the bottom. I ordered a manual, but it has not come yet but i was wondering if there are any bolts located in front by the control arm. I have removed the lower unit and know have the motor hanging upside down and have used pb blaster liberally. Im just not sure if i missed a nut somewhere up front or if the gasket is just stuck from not being removed for 16 years. Any help would be apreciated thanks.
Sureshot
Re: stuck powerhead please help
What about the shift rod connector?
longboard85
Yes i have removed that nut, and have dropped the lower unit completely but im thinking the two bolts that i snapped the head off are holding me up im very frustrated with this thing right now this is the worste time of year for this to be happening.
Daviet
You might try using a little heat on the housing around the broken bolts to see if you can loosen them up enough to remove the power head.
