I have an '80 18' sunray with an aq120b. Sat for 20+ years with fuel in it. There was a ton of varnish in the tank. got most of it out but still have some in the tank.
I am using an racor 500MA filter with a 30 micron filter.
I do not know if the needle was replaced when the carb was rebuilt.
The needle is a bit sticky. Not excessive however it does stick, causing the bowl to go dry.
My question: Assuming that the needle is bad (and I replace it) with my filter in place will that be effective at capturing the varnish (and keeping the needle stick free) or should I be using the 10 micron?
Oh and I can not pull the tank out as it is fiberglassed into the hull. And I did verify with racor that the filter is ok to use with gasoline not just diesel.
Thank you.
Thank you.
