Stuck Mercruiser lower unit impeller
yimmyb
I have a shredded lower drive unit impeller that does not want to be removed. Is there an easy way to remove it?
How long have you left it since you last changed it.
Worse case, using a dremmel, you remove the rubber and score the impeller sleave enough to split it. Then you can remove without damaging the shaft
yimmyb
I have had the boat a little over a year and was having an overheating problem. How do I identify which water pump I have? All I can find is a serial number on the outdrive.
Ayuh,..... You could tell Us what drive ya got, 'n it's serial number,...
yimmyb
It is a 1980 mercruiser MCM 260 with a mercruiser sterndrive serial # 5583873
yimmyb
Impeller was removed. number on pump housing is 46-96148. Internet shows this number followed by a letter and/ or number. Several different styles available. How do I match up these with mine?
