Stuck LU...Use Bigger Hammer?
BlindSquirrel
Before I do something stupid and break something...are there any secrets to removing a stuck lower unit?
Dealing with a Tohatsu 90 TLDI...removed the 6 bolts, and shift linkage pin. I can get movement at front (non-prop) end of LU but back end not budging...one rear (larger than fwd 2) bolt had corrosion on it.
Have hit w/heat gun, dosed w/Liquid Wrench...given some "love taps" with hammer thru 2x4 on top of cav plate, nothing
What am I missing?
Going to go have a beer to cool off temper and internal temp, thanks!
pvanv
Probably the splines are stuck in the crank shaft. Use wedges, patience, and time. When reassembling, grease the drive shaft splines.
