stuck inlet needle?
the inlet needle on my carb sticks when i push on it. It wont release properly. Ive tried wd-40 and gas/oil. Does anybody have any answers? Im stumped and frustrated. Thanks.
Re: stuck inlet needle?
Also, When i blow into the fuel inlet i am getting air....no seal. Ive replaced the gasket so im at a loss.
Mi duckdown
Hey fish. stick with one post. Don't add with different problems with the same motor.
Thanks sunfish. At least you answered my question.
I have already rebuilt the carb. It runs now when I put gas directly into the carb but it will not get a continuous flow. Maybe an air leak in the gas line? I can get it running for a second or two but once the gas is out it kills.
Thanks
Don S
Don't push on it. The needle and seats on some carbs are very pressure sensitive, and some sprays can damage them.
Is the fuel clean and fresh? Rust and dirt in the fuel will stick a needle in a heart beat.
Sunfish12
When it's close to stalling pump the prinmer bulb quickly and see if it stays running. If it stays running its something between fuel pump and fuel pick up tube. What engine is this?
