stuck in reverse
mitretals
59 v4 evinrude 50 Had a grinding noise and is now stuck in reverse. Can manually move shift levers but it makes no difference. Shifter lever works. Can not turn propeller.
OBJ
Re: stuck in reverse
Ouch....hi ya mitre....<br /><br />First thing I would do is check the lower unit oil. Drain it all out in a clean pan and look for metal shavings and stuff like that. Also, post the model number of the engine. Sounds a might old for a 50hp. Don't think the 50's came out till around 1958 or so.<br /><br />Thanks.
eurolarva
Did the same thing on my Chrysler. I took out the shift pin in the lower unit. Kind of sucks because it meant taking the lower unit apart and replace the linkage that broke.
