1971 glasspar
- Mar 28, 2016
- 8
Hi all. I searched. Im rebuilding the twin side bowl carbs on a mercury 80hp 1971. It ran well last year but was hard to start. I figured it was fuel plumbing issues. This year it wouldnt start at all. So, after some diagnosis, the carbs are plugged so bad that fuel just isnt flowing through them at all. Most likely rust sediment as none of the filters I used would take ALL of the rust color out of the gas. I tried though. The whole fuel system needed cleaning and redone, and thats what I did. Anyway, Carbs are off, but the brass screws are all stuck with some thick redish brown glue. It might be red locktite? Ive got carb kits coming in, and I need to get these screws un stuck. Any suggestions? In searching, I havent found any topics at all covering this, here or elsewhere.
So far the carbs are disassembled as far as I can, and soaking. Pretty sure theres some jets and screws and such that need cleaned under those brass screws though.
Suggestions and links greatly appreciated. Thanks!
